[SOLD] New small block Lunati voodoo cam and lifters
moturbopar
mesa az
Solid Flat Tappet Cam. Excellent hot street/strip cam with great torque and HP from low to high end. Needs 2500 RPM stall converter, headers, 10:1+ compression, 3.55-3.73 gearing. Lopey idle.
Advertised Duration (Int/Exh): 264/272
Duration @ .050 (Int/Exh): 235/243
Gross Valve Lift (Int/Exh): .526/.546
LSA/ICL: 110/106
Valve Lash (Int/Exh): .016/.016
RPM Range: 2400-6600
Includes: Cam & Lifters (#70937-16)
Part Number: 30200740LK
Previous Part Number: 60440LK
I upgraded to lifters that allow through oiling of pushrods, so this cam can be used with magnum heads, or regualar. $235
