New torsion bar trouble
jrsbmws
Have 74 Swinger putting in new torsion bars , the driver side went ok adjustment arm all the way down to the adjustment block. Now passenger side bar will not go in unless you raise up adjustment arm to line up torsion bar to go in . The adjustment arm is 1/2"-5/8" up off adjustment block . Called torsion bar people they don't know . Up control arm down to frame , shocks , sway bar off strut rods and lower control arm shaft loose. Help
