[Found!] Non-ac fan pulley
Spadman
74 and still learning
Kentucky
I can’t find a fan pulley for an LA engine without air in my parts pile. I’d love to buy one if someone has a spare. My car is a 1970 with an aluminum water pump. The pulley I need will be about 3” tall as opposed to the AC one that is 2 1/4” tall. I don’t know the diameter. (Edited to add year and measurements.) See the pic I borrowed from AbodyJoe from an older thread below in post 4. (Thanks Joe)
Looks like you have a '71 or '72 Dodge Dart, so that would be small block aluminum water pump application.
Ebay Item #
Check the measurements to see it fits your setup.
Believe that is the correct one for '72 small blocks.
My car is a 1970; aluminum water pump. The pulley I have is 2 1/4” tall and 5 5/8” diameter. I need the taller one, about 3/4 inch taller so about 3”. I don’t know the diameter. The picture below was originally posted by AbodyJoe (thanks Joe). I need the taller one.
