[FOR SALE] NOS Dual Snorkel Scoop
Robzilla
Surrey ND
A NOS dual snorkel scoop for a 73 Dart Sport 340. Never been on a car. Unfortunately it has a small blemish. Right rear corner has a small piece broken off from previous shipment. I have the piece that broke off. Other then the broken corner this scoop is flawless. Should be an easy repair with fiberglass on the bottoms side and some light body filler on top. The broken piece is held on with Gorilla tape on the bottom side for now.. I'd like to get $500 plus the ride from ND.
Update! I went ahead and repaired the corner on this scoop using 2 part epoxy on the bottom to bond the piece back on. I then used a small amount of body filler to smooth and feather the top. I'll let you make up your mind if its a good repair. See pictures.
