[SOLD] NOS Mopar 360 Perf. Block
GTX JOHN
Boulder City NV.
Mopar Performance sent me Six of these 360 Blocks
a Million Years ago.
This was absolutely the best Sonic testing and Core
Shift of them all although they were all quite good.
It is dusty and the paint a bit scratched up from moving
it around forever.
But it is going to be nearly impossible to find A NEW ONE THAT
CHECKS THIS WELL! Probably to even find any new ones would be difficult.
$975.00 Plus the ride
Can deliver in So Cal or Nevada or Arizona
Quick research indicates that part # was for the old Magnum 380HP crate motor. Is that what this block was at one point or...?
Mopar shipped them to me the way you see it.
I did not ask for rotating assembly or want it
for our applications
it has a bolt pattern right down the cam valley , for roller retainers ?
You but you do not necessary need to run the roller cam set up.
All the R Series and replacement blocks have set up from Mopar Perf. for the last 15 years that I have seen that set up in valley.
I use the extra mounts in the valley to run a lifter valley plate and attach it there.
The Mexico high nickel Block is all we run in our Superstock cars except
for very early 360 Block (34xxxxx and 36xxxxx)
It oils thru the pushrods. I run LA heads on my Superstockers
and stockers on this style block but I believe that the pushrod oiling
is more effective and efficient.
Google: John Irving Drag Racer
and my boy
Jon Irving Drag Racer
To see our stuff.
It does have the tunnels cast into the block to permit
oiling thru the head. The hole would need to be drilled
but my block machinest says that is not hard to do or expensive!
Seems like a fair price for a new block . I am really suprised no one has grabbed it . I have a used 71 360 block that I wouldnt sell for less than 400$
Mopar has not cast any new HP Small blocks for
a number of years and none on Dealer Parts Locater
either last time I check.
