[FOR SALE] NOS Mopar
AngelE
Member
WI
Rating - 0%
0   0   0
#2203472 filler seal $20
#25-42S Carter carb needle and seat assembly for 1930-31 $22
#1137342 Mopar 1949-54 Desoto trans gasket $18
#854801 Mopar gearshift housing gasket $7
#1329-961 Mopar oil pump gaskets, set of 8 $14.00
#1406164 Mopar power steering filter cover gasket $5 each/3 available
#1853891 or #1638666 Mopar automatic 3 speed case extension gasket $12 each/2 available
#853895 Mopar 1940-54 3 speed standard trans gasket $20
#1636303 Mopar 1957-61 auto 3 speed w/8 cyl. valve body gasket $20 (set of 2)
#1326836 Mopar 1951-76 Dist oil return steel gasket $17
#1730095 Mopar fuel sender retainer $15
#1408518 Mopar A body trans case adaptor $10
#1112607 Mopar A body gear shift housing gasket $20
#1735036 water pump gasket for 1957-59 Dodge truck with 6 cyl. $12 (set of 2)
Everything listed here can be seen on Ebay as well. Just enter the part number on eBay's site and every listing has pictures. Please personal message me if interested or questions. We are willing to take best offer on most. Thanks.
#2203472 filler seal is no longer available.
Okay, so I'm just curious if anything listed here is worth keeping. I would like to see it get into the hands of someone that can use it, but if it's junk, no sense in keeping it. Any thoughts??
