NV3500 question
Shadow9198
Active Member
berta
hey guys. in my 5.7 hemi swap project i put a 5 speed nv3500 from an 01 ram 1500 truck behind the engine (i know its not quite rated for the hemi torque but im not planning on bag driving it so it will last for a while). i bought a slave and master kit for that same truck. with the kit it has that ridgid plastic hose for the fluid line and it wont line up with what im doing. is there a company or something that makes new fittings that go in to the slave and master where the plastic one does that will convert it to a female brake tubing style fitting?
Yes, we sell one for doing Magnum swaps into Wranglers. Its a kit with a braided line and fittings. It comes with 2 brass fittings that hold original O ring and are secured with roll pin, and a 42" -3AN braided line with 90* on one end and straight on other. We also have a kit that replaces the line on a YJ wrangler which had an internal slave/TO bearing which you can also use. PM if you are interested. Both kits $89. Evan magnummopar.
