Offset shackle kit problem
74scamp360
Junior Member
Elora, Ontario, Canada
Ok, so i bought the offset shackle pieces from chrysler, not the relocation kit just the offset front hangar brackets and offset rear shackles. I was playing around with it today on the scamp to see how it looked and the front hangars won't fit in because of the nut welded on. The only way the hangar will fit on is backwards so its actually moving the spring out not in. Has anyone had this before? I was thinking the route to take would be to drill a hole in the frame so that the nut that's welded onto the bracket will fit into the frame. What do you think?
The Mopar Performance offset hanger kit requires that you cut a small hole in the frame rail. There are some other companies that make kits with a flat head so you don't have to cut into the car, but if you already have the kit you might as will use it. It is not a big job and you can do it in no time.
