Offset spring hangers
rapom65
Battle Ground, WA.
There is a set of offset front spring hangers on Ebag right now. With minor elongation of the top two stud holes in the body mounts these will work in 64-66 also. Sorry guys don't know about earlier than that.
I can see where this would help with wider tires without mini tubbing.
Absolutely no clue what you're talking about. I put a set on 2 cars I had. A 65 Valiant and a 71 dart. Neither required any mods whatsoever other than drilling a hole in the frame rail on each side to allow the welded on nut to protrude through.
So I can run factory wheels on my Barracuda. Post #28
http://www.forabodiesonly.com/mopar/showthread.php?t=135553
I'm sure you can run any factory wheel ever made for an A or B body. I had 15 X 9.5" Center Line Auto Drags on my 65 Valiant. Only mod I had to do other than the offset hanger kit and move the perches of course, was to roll the inner lip of the outer wheel well up against the inside of the wheel well. I had 28 X 11.50 X 15 Mickey Thompson ET Streets on the back. The only time it would ever scrub was very slightly with my son in the back seat and a trunk FULL of groceries from the Kroger. I had the 002 and 003 SS springs.
Where did you pick up those springs?
That was a LONG time ago...but you're lucky. Because I bought two sets at once I got a really good deal. Westoaks Dodge in Thousand Oaks, California. I've actually gotten quite a few things from them over the years. They always did me right.
Thanks I will check them out.
