Oil Breather Leaking
HemiTM
Loganville, Georgia
I am using valve covers similar to these. Problem is the twist on oil breather cap leaks bad. I would like to convert to a push in breather cap. Are there any conversion kits available?
No conversion kit I know of but I converted one to a push in breather by purchasing a grommet from Summit and silicone'ing it in place. Never leaked a drop.
BTW: do your valve covers have baffles? If not that may be one reason they leak. Baffles deflect the oil slung off the rocker arms.
Do the caps have gaskets? Do they tighten down real firm? Sometimes, you can bend the little tabs to make them tighten against the gaskets better and seal up.
