Oil filter adapter gaskets
Dartsun
Mopar Dude
Springfield Oregon
I'm looking into buying the Mopar performance oil filter adapter kit for my 273. Was curious on where the 2 smaller gaskets went on the bolt. One on the inside one on the outside? Thanks dustin
The black smaller one goes under the head of the bolt on the outside of the adapter. The cork gasket is installed on the inner part to keep the oil from recirculating without going thru the filter.
Yote
there is a picture floating around here somewhere, but Yote has it right, the bolt goes through the black washer (steel or some other hard material) then through the adapter, then the thicker cork gasket and then into the block
i don't know what jegs charges, but there was a member here selling those kits for 15 dollars (and i believe that included shipping)
check the for sale section if that's a deal
