66 Barracuda - pulled 318 motor and trying to install new 408 (360) with Milodon high volume pump. I do not have enough clearance between the top side of the K member and the bottom of the block where the pan bolts on. Not sure why, being I've heard of guys using this same pan. I do have the correct motor mount and resonators from Schumacher (A63LA) - this was a S6 car originaly. The instructions do state that you "have to use an original factory low profile oil pan" but I'm certain guys have done this before.
Any information is appreciated - Fab mounts to raise motor? Fabricate front shallow area of pan to fit?
TIA
TIA
