[Found!] one cap for 8 3/4 742 case
to find a carrier cap that will match up to the threads in your case is going to be a long shot and also the bore has to be the correct size for the bearing race --- the carrier caps on any 8-3/4 case are like the main caps on an engine they only fit that case ( or engine ) as they are line bored and threaded when the case is built and must be used in the location they were machined in --- you cannot even switch the caps side to side -- that is why you mark them before disassembly.
just look for another case.
Mark Williams sells individual caps which are designed to be machined to fit. There is one side that can break first in some race applications and these are much stronger. Can be used on both sides for added insurance. But it's probably be more economical just to get another bare case for milder applications.
