mikess68
need to know the following about original color of 72 dodge dart:
color of heater blower motor
color of wiper motor
power brake boster, anodized or black
did the exposed wires on the wiper motor ever have a cap? you can view the soldered wires on a tan colored circle attached to the aluminum base.
were all wires that run over the power brake boster to various parts, wrapped together or just loose
power stearing hose, one has formed metal ends, the other is just a hose with clamps?
color of hot wire from battery
is heater water valve cable or vaccum
did/is there a check valve on the vaccum bottle mounted on the inner fender like on GM's
were spring covers on brake lines metal color or black
and some more later.... tks for any help. (yep that means im getting closer)
