Overflow hose size?
sabre67
B.C. Canada
Hi all, quick question, what size hose do I need for radiator overflow hose on stock Mopar rad? Thanks sabre67
Continental has the correct overflow hose. Part number is 65099. It is 30 inch by 5/16. I've found that 30 inches is usually not enough. I splice two together and then cut to length. I use a brass 5/16"splicer. This is the correct thin wall tubing. Again, I would order two.
You should be able to get it at you local parts store that carries Continental belts and hoses. I saw it was available on Amazon.
