[SOLD] P4529973 Mopar 304/571 A Engine Solid Camshaft
GTX JOHN
Boulder City NV.
Brand New in Original Box
A Engine Solid Lifter Cam
It was designed for Mopar Oval Track Program
It is on a tight 106 Lobe Center and not 112 like
the Drag Cams used to be put on.
In our Dyno Tests it made Significantly more Mid Range
Torque than the Wider lobe Center
(Approximately 20 Ft Lbs @3500 - 4500).
It had a bit looper Idle but not terrible.
It is camshaft only as i used the lifters on another Race Car.
$175.00 plus the ride
