painter question what can i use instead of ppg dp40?
fez440
bc canada
question for any painters out there. my car is covered in ppg dp40 primer but i have done some metal work on it and there is areas of bare steel. since dp40 is not available anymore what is a good product to use to paint the areas of bare steel. something that works with the dp40. and where can i buy it in canada?
thanks for any help
DP40LF is the lead free version. However the Omni MP series works well too. That being said any good epoxy primer will work for you.
thanks for the reply. i will see if i can find any dp40lf
