[Found!] Park brake cable bracket
1994redram
Oklahoma
I moved my springs in 3 inches and removed the bracket from the cut out piece of frame rail. I put it somewhere I wouldn't lose it, well it's lost. It was spot welded to the drivers side inside of the rear frame rail. Both parking brake cables go through it. I need a non rusty bracket and maybe the retaining clips if possible. It's for a 1970 dart.
I believe this is the bracket I used. I know it says b body but if I recall correct I had found somewhere that tied it to a bodies. It’s been a while.
I ordered that B body bracket. Got it in the mail and started tearing the garage apart looking for some other parts and found the original bracket I cut off! Good news is, they are the exact same pieces. Bad(ish) news is, I now have two of them.
