[FOR SALE] Partial A-body Four speed conversion lot
Hemihead2
PA
The pictures show everything that is included in this sale. It is not a complete turn key conversion but most of the big pieces are there. First, the A-body A833 is from a 1972 model and is definitely NOT of the OD variety. I popped the side cover on this one and it looks great and shifts by hand easily although I have not run it personally. Also included is a small block bellhousing, A-body pedals with clutch switch, clutch rod, Z-bar, used 10.5” factory flywheel, clutch fork/ dust boot, shifter boot/ bezel, used clutch and PP. Also included is a hurst 4 speed shifter with a bolt in E-body pistol grip handle. The levers and rods are present as well.
***What you will still need to convert an Automatic car over***
outer frame mounted z-bar bracket, upper starter shield, lower clutch cover, A-body 4 speed hump, floor shift steering column (optional).
Asking $1,500 for what is pictured...
I may split up if I get enough interest in all the pieces separately..
Located at 16602 pickup preferred
