parting 74 dart
ramcharger1990
New Member
huntley, IL
Rating - 0%
0   0   0
i have a bunch of parts they are from a 74 dart four door but some parts fit swinger, sport, and also plymouth model valiant, scamp call and i can text you a picture
complete set of tail lights $30
both sides top of quarter panel extensions all mounting point are good $25
rear window glass in good condition $25
truck lid with no rust at all good condition $40
all four doors complete no rust but rear passenger door hsa small hole in it about quarter size. they all the hardware on them the drivers side wing window is broken all doors $80
complete ac unit from inside of car to the condensor with mounting brackets and i cut out firewall if you what to make it look like factory install $175
instrument cluster all guages tested good $40
the front bezil good condition it is from se model so it has the se hood ornament still intact $40
grill with turn signal lenses $40
i have two steel rims small bolt pattern with new tires on them 185-75 r14 $40
also have early 80's heads complete and four barrel intake with carb $125.00 obo
hello, I need both taillights, headlight bezel and the panel is between them... $$$$$???
