Pentastar location for 1970 Swinger
Hemiorangeswinger
Dodge Material
Edmonton
Hey, does anyone have the exact location for the passenger side fender pentastar? (as well as the hole sizes) My AMD fenders never came with the holes. This is for a 1970 Dart.. I’m sure 67+ are the same.
Can't give you an answer on the correct placement, but I suggest cutting the mounting pin off an use 3M trim tape to attach it and eliminate the hole and future rust issues.
+1 on the trim tape. I used old road test photos to get mine as close as possible to stock since I could not find pinpoint directions.
On my 67 it is 5 inches from the rear of the fender and 7 up from the bottom of the fender (not the mounting flange of the fender)
My 70 Swinger, 5” from back of fender and 7.5” up from the crease on the bottom of the fender.
I made a cardboard template from a friend's '69 GTS and used it to locate the spot on my '69 Swinger. Agree with Dragonsteel on the 3m emblem tape - did not want to poke holes in my fender.
