I replaced one in my 489 case, bought it at napa. They only list 2 part numbers for seals and I can't remember which one I bought. It did the trick, no more leaky.
They list part #18708 for 1.375 and 1.875 pinion
And part #18912 for pinion 1.750.
Not really sure how the pinion seal works for big and small, unless the part of the pinion the seal rides on is the same for both? I've never seen a 741 pinion so I'm not sure.
Edit: After looking a bit more #18708 is the one you definitely want. Cheers
