scott657
318 "stock" rebuild.
Im going to have the pressed in pins removed from the pistons
going to run these pistons
Silvolite Pistons 1266-STD Silv-O-Lite Cast Pistons | Summit Racing
Im going to have
the rods drilled for clearance to the pins
is .0005, the "correct fit" ?
Thank you FABO
Im going to have
Thank you FABO
