[SOLD] Players VS Posers sale
1966Post
Wisconsin
A huge lot of small block parts
2-318 roller blocks. One is .030 over and the other is .040 over. (4) Cranks cast crankshafts. (One is a 273 steel crank stnd/stnd) 2 sets of 714 closed chamber heads (same as 302 heads but less prone to cracking between cylinders) One set had "249" 340 springs installed. Rods pistons A box of miscellaneous throttle linkage/brackets Several SB balancers. Flex plates. A stnd/stnd 340 cast crank w/correct balancer. An 230 A-body 3 speed bolt-in ready
Rocker arm/shaft set $150 for all. Pickup in central Wisconsin. No shipping. This is a 3 Musketeers sale. One for all and all for one ..
Thanks FABO
Adding a few parts and lowered the price to $125
Pair of nice 675 casting heads off a running engine and a set of chrome valve covers w/T-handles that will clean up with a little effort
Come-on players the losers are winning
I will also provide all the beer or Jack you can drink while we load the parts up in your vehicle/trailer. Maybe Ole'Kimmer or Rusty will come now!
Sorry I'm so far away & getting ready to move, too.
If you can't sell it for your more than reasonable price, I'd really appreciate it if you'd try to give it all away to some local worthy mopar fan before scrapping it.
Thank You!
Id be interested in some of it..
Again where in Wisconsin?
NW of Wausau Wis about 15 minutes. Straight north of Hwy 29/107 Marathon City ramp. I would like to see it go to good use. Just need the room
Well I don't need the linkages but I certainly do need everything else especially the 3 spd and engines/parts Wausau is 2.5 hours from me
Wausau is about 6hours each way, as I remember/ I'm out unless someone else "in between" gets your stuff and I got what I wanted from them......(not saying that the other guy won't want exactly the same goodies I do)
