Please help with heater control cable positioning
69GT
Metro Detroit
It's been so long since I originally took my 69 Dart apart that I'm having trouble remembering where/how some things go. I'm getting close to re-installing my heater box and the dashboard. I could use some help with the positioning of the heater box control cables. If someone could tell me which cable goes from each pin on the heater controls to which door pin on the heater box I would appreciate it. One cable is considerably longer than the other two and has a red band on it and the other two are similar in length and have yellow bands. Also, which end of the cables goes on the controls and which on the box? One end of each cable has 5 coils in the loop on the end of the wire and the other ends have two. Thanks in advance.
MyMopar.com
Download your cars Factory Service Manual.
There are photos for routing AND there is a procedure for adjustment.
Does this help. Colored tape is on the cables at the box. The color letter is written on the controls in marker. R, W, Y. You can clearly see the red and white in the pics. The other cable (yellow) goes on the remaining door and control pin. BTW.....This was before the restoration. I didn't re-install it as is. LOL:)
Edit: Here's one more....
