Power Brake booster hose location?
wes beem
ohio
Probably a stupid question, but I've never had a power brake classic before.
Where does the brake booster vaccume hose go to on the motor? Intake? Carb? Valve Cover?
Post some photos of the top rear of your intake and carb.
Your intake may not have been drilled for a booster.
Your carm MIGHT have a manifold vacuum port.
2 possible manifold ports that I can see.
If neither is a manifold vac port you might have to use one of these.
Or dump the power brakes. Totally not needed on an A body
all the Edelbrock carbs have a power brake tap in the back of the carb at the base - usually closed off with an allen wrench plug if not used
Take the plug out of the first one pictured and use it for the power brake vacuum port and put that plug in the second one pictured or you'll have a water leak.
That other hole is just an LA pattern bolt hole. This intake is drilled for magnum and LA
Not sure why this is a thing thats still being pushed on here. Everyone's situation is different. Maybe they don't want to deal with manual brakes on a car that already has power (why get rid of something that works and makes life easier) might be a pro-touring build with 6 piston calipers and large wheels&tires.
Yes you are correct, I was just offering options. Some people think that all cars need power because they have never driven a non power car.
In my case, the entire brake system had to be completely redone anyway, the car was originally small bolt pattern drums all around with the crappy 7 1/4" rearend, and the Power kit was only 100$ more than the manual kit at the time. That being said, after all the issues and stuff dealing with the power brakes, if i had it to do over i 10/10 woulda left it Manual because there was nothing wrong with my manual disc 70 Dart i had back in the day.
Every Mopar I have seen with Power Brakes the hose was connected to a port on the intake manifold.
Alan
What sort of problems are you having with your power brakes? My mom wants me to add power brakes to the 69 Charger... She hurt her ACL a few years back and using manual brakes just isnt something she finds enjoyable at this point in life.
Now that is a very valid reason to add power.
Firstly, All of the "direct fit" Lines are NOT direct fit....wrong thread pitch fittings for master cylinder....then had to cut the ends off and have new ones flared, then those leaked everywhere, also couldnt find anyone who made lines for DISCS in the rear so had to cut and modify again to try to get drum ones to work, both of those leaking fluid too due to the stainless lines not taking a flare worth a damn. I wish i would have left it manual front, drum rear and just full sent it with a classic industries oem line kit and been done with it. Also, with the added bulk of the booster, it makes working in the driver side of engine bay a real pain in the rear. I just dont know that the bennefit of power brakes is going to be worth all the extra hassle and hidden costs. To be determined once its drivable, but i know my dart had NO issues stopping under duress. Zanesville people love to run stopsigns and redlights and pull out in front of you then slam on the brakes when they see you to make sure you T bone their ***...
As my dad always said...
The parts you don't add don't cause you no trouble.
I feel for you.
But it's not to late to go back.
And while everything is exposed will make it much easier!
I feel for you.
my 70 dart was significantly easier. bought a brake line kit off ebay, stuck it on. Put in a new master cylinder. bled it, done.
