[WANTED] Power Lok spider gears
68 bee
ny
While replacing the clutch plates and discs in my 1967 8 3/4 rear with the Dana power lok sure grip I noticed one of the 4 pinion/spider gears was damaged. I know Dr Diff sells the whole replacement kit but only 1 gear is bad. Everything else was good. I would like to find a good used gear or 2 to replace it from someone who had the same problem and just replaced the whole unit. Anyone have the gear that they want to sell?
Here is a picture of the bad gear.
PM me if you can help
