Power Steering Brackets
billytuffnuts
Newport Beach, CA
I have two sets of power steering brackets, both are for saginaw power steering pumps.
The first set of brackets I believe is for small block engines with the cast iron water pump (68-69), or at least thats what I'm told they are for. Also have a saginaw p/s pulley that came off the pump that was attached to the brackets. Has a small ding on the lip of the pulley but shouldn't affect anything.
The second set is for the 70+ aluminum water pumps (small block engines). Doesn't include the bracket that bolts to the timing cover, what you see pictured is what you get. Two of the brackets I began to wire wheel and prep for paint, the 3rd is painted black, but they should all be repainted to look nice again. If you can see in the picture below, the middle bracket has a larger than normal hole (not sure what happened) but I used it with no problems, just had a big washer.
$30+shipping for each set of brackets
$10+shipping for the pulley
