Procomp Electronics headers
Duster_71
PA
Hello all,
Has anyone tried these headers found on e-bay? Currently $116. What are your thoughts?
Mopar Chrysler SB 318 340 360 Block Hugger Stainless Steel Exhaust Header
Brand:
Procomp Electronics
Part Number: PCE316.1068
Part Type: Headers
Header Style: Short Length
Header Material: Stainless Steel
Header Finish: Natural
Weld-Up: No
Primary Tube Diameter (in): 1 5/8 in.
Collector Diameter: 2.500 in.
Tuned: No
Primary Tube Gauge: 16 gauge
Flange Style: Standard
Flange Thickness (in): 3/8 in.
Bolts/Studs Included: No
Gaskets Included: No
Reducers Included: No
Y-Pipe Included: No
Motor Mounts Included: No
Transmission Mount Included: No
I had a pair of these. Held them next to the car while looking in the engine bay and put them on sale right after that.
The centerdump exhaust doesn't work with steeringlinkage.
will not fit many cars, and at $116. - about 1% stainless - check with a magnet - quality stainless is expensive, non magnetic, and will not rust. cheap "stainless" is magnetic and will rust
My thought is that you have a steeringbox in your a-body that is a kind of of critical component to be able to drive.
Also, look at how thin those flanges are. And no raised bead around the ports. Nearly guaranteed to leak. That is assuming you can find a vehicle they will even fit on.
