Project D-$150
Houseoffubar
Puyallup Washington
No, my D-150 pickup is not an A body. It is a Mopar though! Out of respect, I will try to keep this to motor and drivetrain, and not clutter up the A-body thread with pickup trucks.
This thread is named for the model truck and the price I paid for it.
The theme of this build is going fast for extreme low cost.
I am not a total of:
$150-truck
$70-battery
$32-manual
$100 wheels and tires
$175-turbo
$50- suspension parts
The day I bought this truck (88 D-150) I went with a (reconditioned $72) battery and this 318 that had not been started in 5 years, popped to life and after blowing out 1 injector, and putting the wires on the right plugs, drove us home, and has run like a top since.
A fairly low mile vehicle, it all, especially the motor, looked and ran well.
the goal here is to turbocharge this stock 318, get some decent daily driver power, then build a new “turbo motor” to drop into the truck.
This 318 will then get touched up and be installed into our ‘67 A-100 van.
The goal is about 400whp with the current motor, then around 600 for the actual “turbo motor”.
I grabbed some decent alloy wheels and a pair of 295/50-15 Cooper Cobra tires.
Ordered the turbo and mounted a steering wheel, with my homemade adapter.
Truck or not, I'm always interested in a turbo project. You say "injector", is it TBI? I'm curious what you intend to do for spark retard & fuel enrichment under boost.
$150-truck
$70-battery
$32-manual
$175-turbo
$150-truck
$70-battery
$32-manual
$175-turbo
Yes, 88 was the first TBI. It was also one year only and quite small, so zero performance potential. I will do a blow through carburetor, at least initially.
I intend for a digital wategate controller and perhaps an MSD that will allow ignition retard with boost, I will need to do more research on these two items before I settle on one however.
$150-truck
$70-battery
$32-manual
$175-turbo
Awesome! Doing the same thing myself with a '80 Dodge (my avatar). We almost went turbo 318 but decided to go 440 instead. And there are a lot of threads that aren't A-bodies, including my truck so no problem there. :)
Nice truck!
Looking for info online, I kept finding the answers here, and everyone has been very knowledgeable and friendly. I’m glad everyone has been so welcoming!
Yeah, 440 is hard to beat! I had thought about a big block swap, but with our old ‘67 A-100 van having a 318 as well, I like the idea of sharing and passing down parts.
So, I have been collecting parts and finalizing the plan.
One major change is for now this truck will stay a daily and keep my expectations realistic (400-450hp) as I will be using this truck to pull my dragracer!
I picked up a little 65 Datsun that I am putting my 600hp Turbo 5.0 into.
Just based on power to weight, it should do mid 8’s. I will be pretty content with anywhere in the 9’s, this tiny thing should come in just under 2,000lbs, so it should be a handfull
Anyhow, back to Mopars!
I believe there are simply times money must be spent for quality, but the older I get, the less I like to waste money for bling or anything unnecessary to accomplish the goal.
As I am learning I have found several ways to save big on this build and still get what I need to go “fast” and keep the motor healthy.
The first is: no intercooler! Never thought I would say that, but as I am learning, low boost (or lots of fuel) through a carburetor cools the incoming charge as much as an intercooler, and sometimes even more.
I also found some ignition cheats I will try to save several hundred $.
I need a distributor and planned a fancy setup/MSD w/ boost retard, but read about running an HEI module wired to a stock Mopar distributor from an 80’s GM car. These (5 pin) HEI’s have a 5 degree retard simply by grounding the 5th pin using a Hobbs pressure switch.
The new OEM HEI unit was $10 and an adjustable Hobbs Switch $25
Watching Roadkill’s $3 Hooptie challenge, I added my parts in my head and realized I think I can have a 12 second truck for $1,000!!!
Well, not quite, I added on paper (always gets more expensive when I do) and I am at $1,040 and still need rear slicks and a posi.
So my goal is to turn a 12 second pass in my daily driver for under $1,500, cost of truck included.
I may have to drop a welded rear end in to make this happen, but we will see.
Thanks for watching. I will start the fab work very soon
