moparmat2000
another suspension question. i was looking at the prothane upper control arm bushings kits. the kit i was looking at you leave your stock outer shells in the upper and lower control arm, and just insert the polygraphite bushing along with its inner sleeve, and end thrust washers. (these are the ones without an outer shell) prothane # 4202 $16.17 set of 4 you reuse your old shell by burning the center rubber out.
i have used this type of bushing setup on a set of upper and lower control arms on my 94 chevy pickup. those were made by energy suspension. worked really well, torch out the center leaving outer pressed in the arm, snap in new center and sleeve, reinstall. i have had these in the truck for 100,000 miles so far, no deterioration, or looseness in the front end.
this would be easier for me as i dont need to have a puller / installer tool, even tho i have seen one here i could duplicate thats homemade and pretty spiffy. besides the fact that these are cheaper and easier to install on the UCA as upposed to the ones with the steel outer shell. whats the downsides to them?
i have the polygraphite lower control arm bushings like this, along with the greaseable pins from firm feel.
any ideas any advice.
i am asking these questions only because
A i dont want to do the job over because of cheap parts
B i dont have extra cash and want to spend it wisely
C i want the car safe and functional
thanks in advance
matt
thanks in advance
matt
