NukeBass
I've done a few different searches and went through a few posts (there are lots of them depending on search criteria) that discuss dynamic compression ratio and pump gas. Most of them seem to agree that 8.5 is the max DCR to target for regular pump gas compatibility, I think, for 93 octane, but that's generally as much info as I can find. I also found on the web this website that has a table for DCR vs. pump gas, but it is the only one I found. http://classicinlines.com/CompressionRatio.asp
Since it is on the web, I generally like to find a couple of sources with information before really trusting it and this chart shows that you can go as high as 9:1 on 93 octane.
Is the classic inlines chart correct (which would be nice since it breaks down different octanes) or should I use something else, like the general 8.5? Thanks!
