question: rallye cluster...
danmc77
Barto, PA
On a Rallye cluster, what are the 2 holes in the bezel below the clock/tach/vacuum gauge? The 2 above the gauge are turn signal indicators - can't figure out what the others are.
If they are for high beams or something else - are they supposed to have a film lens over them?
One is a high beam indicator & the other is a brake indicator. The lenses are black with colored printing on them. unless you light them up you can't tell that they're even there. Pull your parking brake lever with ignition on & one will light. Turn on high beams the other illuminates.
Thanks! I'm installing a rallye cluster and my donor cluster doesn't have any lenses. Does anybody reproduce them?
Actually I think the brake is red with black letters and the hi beam is black with red letters, at least on mine it is that way.
