question
AbodyJohn88
in your opinion how much boost could i push through a fully forged l.a 406 with 9.3 compressin ratio and a novi 1200 before i have to start backing timing out or worrying about detonation running on pump 93............
I would probably think about taking timing out with any boost. As far as detonation it will depend on how warm the intake charge is and if your going to intercool or not. I would guess you could go 5-6 pounds on pump gas and if you go methanol injection as a supplement you may be able to go as high as 20 pounds.
