Swingin1970
Fresh machining from QMP, ex pro stock truck block.
Building a larger tall deck W8 engine so this block needs to go.
Mopar Performance 4876381AB
9.016 height, square decked
Uses 60mm roller cam with bearings installed
48 degree
liter bores bushed and honed .904
4.200 bore diamond honed with torque plate
Sonic checked can go 4.225
Short fill to bottom of freeze plugs
4 bolt aluminum 340 mains with ARP studs line honed
Block requires a motor plate
External oiling Wet or Dry sump
Blocks ready to build located in Santa Barbara Ca
Asking $3800 for the bare block, willing to assist with crating and freight worldwide.
48 degree
