Hello I have been doing a lot of research on whichbradiator to use and would like to know what others with much more experience would recommend. I have a 1972 model car with 22 inch radiator opening. My engine is almost finished hopefully i will pick it up this weekend the builder had to search far and wide for an intake manifold. It is a 360 with 9.8:1 compression, stock crank and rods, internally balanced, comp 276 cam, big valve j heads with mild port cleaning, using 340 exhaust manifolds, edelbrock air gap intake, and holey sniper. I have the classic autoair kit so it will have an ac condensor in front of the radiator. also borgenson power steering pump and steering box. It is a 4 speed car as well. I would like to run a mechanical fan with thermal clutch. It isn't going to be a race car but I figure it will be plenty strong for the street and was wondering what you guys would recommend as far as a radiator?
