radiator
Bigdummy
Not a Nova
Cleburne,Tx
What years and model cars will fit my 69 Valiant.The one I got is way too small!
He must have not fallowed up, you are still in need of a good cooling system, I know better then to ask if it is tuned right and not running lean, so it must be the radiator and air flow
across the small thin fins.. Looking and I hope some tech's can jump in and direct us to a fit/formula to keep the engine cool, lord knows you know what you are doing
Are you sure you need a bigger radiator? You know it could be your crappy fan and lack of a fan shroud.
When does it get hot? At idle and low speed, stop and go traffic?
I just noticed the lack of a good fan 1968FormulaS340, That fan is not made for road use from what I have learned , great for no HP drag, but will not move very much air...
