green440duster
Hi my friend has a 71 Duster with a rallye dash, all of his gauges work except for his oil pressure gauge, the cluster seems fine otherwise and he said that a guy tried to send a signal (not sure if it was voltage or grounding) and the gauge responded. I told him that it might be the sending unit but he only has an aftermarket sending unit. I have never seen a factory rallye 340 oil pressure unit, are they different from a modern(78??) unit or should I get him to check something else.
Anyone shine some light on this problem???
Thanks
Thanks
