Rear Disc Conversion parts?
mguner
How many is too many?
Amarillo,TX
I've noticed there are lots of ways to go with this. The Lincoln parts used to be the way to go but now everybody makes some sort of kit it seems. With or without park brake is also an issue since I believe most states require it for MVI. I am talking 8 3/4 with 5 on 4 1/2. I am interested in hearing what works and what is junk.
Lot's of different kits available. Or you can put your own together from different manufacturers. Iv'e been piecing together my own it will fit any rear as it has multi fit rotor hubs, and replaceable rotors. The calipers are wilwoods with a weld on mount. I have approximately $125 invested in mine, that's having 12"x 1.25 vented rotors with 4piston calipers.
That sounds very reasonable! Do those calipers have the park brake option?
