Rear Quarter Glass Install
charliec
richmond texas
Can anyone suggest a good video on installing the rear quarter glass and regualtor for '68 Dart 2DHT?
I couldn't find any when I did mine, (a few years ago). But they weren't much fun. After I got the window in and "close" I made some sharpie locating marks near the adjusters for reference to adjust from where I was. Only because a couple of times I loosened up the adjusters to much and the window slid back down the guide track and then I had to start over. PITA. But I finally got them pretty close and decided it was as good as I could make it. Also, wear some long sleeves to keep from scraping your arms on the sheet metal fishing the regulator into the openings and getting things into place. I'm sure the factory had some fixture that they had in place that located where things had to be for all the angles/pitch to be correct without having to spend any time doing adjustments. There might be something on the web now since I did mine. I used the FSM for a starting point, but for me it was mostly trial and error. Good luck!
I just did this on a ‘70 which is like very similar although I haven’t installed the glass yet which I think is the easy part. The regulator can go in at least 3 ways but only 1 way works :) The order in which you slide the rollers into the various tracks is critical. I did find a video that helped some
Should any of the various rollers, slides, balls, pivots, and gears be lubricated? If so, with any particular kind of grease?
