timk225
1973 Duster, 225 Slant 6, factory A/C car, all original components are present.
Since the car sat in storage for 20+ years, of course the A/C isn't working. I'm looking for ideas on how to get it going again, and if anyone knows of a good A/C shop in my area (Pittsburgh) that can handle older cars.
By using a rented vacuum pump, I was able to determine that the vacuum motors for the water valve and the defroster are leaking. No surprise. Might as well change the other 52 year old motors while I'm at it. Year One doesn't have them, anyone know where to get them? The vacuum reservoir appears to be good. I changed the hose running from the reservoir to the intake manifold vacuum tap. The new hose is a silicone 1/8" ID hose, and although it is smaller for less leak potential, you can hear a noticeable change in how the engine runs if you let the hose leak to open air.
The thin copper tube coming off the expansion valve fit loosely into the big pipe it goes into. Probably going to have to change at least one pipe as a result.
Condenser and evaporator probably need flushed and tested, if not replaced. A new receiver / dryer is a given.
Classic auto air has a kit for $2200, but it is for a 1972 Duster. May or may not have issues with my 1973 if any parts were changed.
Any thoughts?
Any thoughts?
