rebuilt 383 blues
mlongboat
Member
Ohsweken
tanked rebuilt, 383 68 block. Galley plug missing somewhere, Dribbles at oil gauge fitting at back of block. Should hit ceiling.
Am I missing oil galley plug somewhere?
Need help with galley plugs location.
any and all help would be appreciated.
summer is almost over, help
what about the plug, at the front
under the cam
while priming the pump
You can see/hear thru the fuel plate (removed)
a gush of oil
New oil pump? What oil filter? Could be the pressure relief valve in the oil pump is stuck open. It's also easy to crack the pickup tube by the threads. How far off the bottom of the oil pan is the pickup? Are you checking for pressure while priming the pump or cranking engine? Not trying to be short just throwing out some thoughts and maybe get a little more info on the situation.
