Remote mirror cable tie?
KenZ
What kind of tie/clip is used to hold the cables from hitting the door glass? Anyone know where to get one?
Thanks,
Ken
I think I can help you with this if you're not in a hurry.....:cheers:
It is a piece of spring steel resembling a clip that would slide onto the edge of a piece of sheet metal inside the door....if I remember right. If I had one, it would be yours.
Good Luck.
George
This is the bracket that held the cable out of the way on my '70. However, when I went to reassemble I could not, for the life of me, find the mounting point inside the door. I ended up tying it out of the way in a couple of spots.
:thumbup: Many thanks to russduanegreen for offering the clip to KenZ......Nice networking job there :-D
On the front part of the door.If you unscrew the three screws that hold the weather strip to the door you will see a large hole.That is how the bracket is secured to the door.
