Removing 66 Cuda chrome trim?
bbeep71
N Providence
How do you remove the chrome trim on the top of the rear quarters joined with the tail-lights and also the chrome pieces near the bottom of the rear window near trunk?
Thanks
Happy 4th
you have to un bolt the tail light housing then the trim piece can be pulled off. In the trunk you should be able to squeeze the clips from underneath to pop the trim off. Be careful the stuff can bend and scratch easily.
Thanks Dave,
My friend just picked up a 66 Signet Conv. It's from Ca. relocated to RI.
bbeep71
Be very careful when removing the trim, it bends very easily. Check for 1 or 2 mounting studs, my 66 Valiant had 1 on each side along with the clips. Use a pliers to squeeze the clips, then carefully push it through the fender, do this for all the clips and eventually it will lift off.
