Removing 75 Dart back seat
start with the bottom cushion. you have to push down, in and up on both sides about a foot in from the side panels , i like to move the front seats all the way forward and crawl in there and use my knees. once you get that out, you will have to remove the bolts or bend the tabs on the bottom of the back section, and then lift up and out. it helps to remove the arm rests ...
build sheets can be found here; bottom seat springs of any seat, behind the back seat. under the carpet, in the headliner, behind or on top of the glove box liner. inside the console, under the package tray, there may one, there may be three, there was no specific protocall for placement or number of these things. i have even found blank sheets
when i went searching for mine in my duster, i found one behind the top rear section of my backseat, unfortunately, it was only one little corner behind the spring and the rest was in a million pieces. it was the only one. the fendertag duplicates most everything on the build sheet .
My 75 Dart had 2 build sheets. One under the back seat and one under the front drivers seat. Dan
I have heard some people say they have found a build sheet on the back side of the glove box under the dash.
Where is the fender tag generally located...and please don't say the fender! LOL I have looked but don't see anything...probably looking right past it.
its on top of the inner fender well next to the battery, if its there you will see it, if its not, you will see two screw holes where it was...
