Has anyone removed the worm shaft seal on the power steering gear box?
I saw in plymouth manual they use a special puller that slides over
shaft and the ends has threads that dig into seal. Then a bolt on other
end is tightened to pull seal out. similar to the trans shift linkage seal puller.
I wonder if a curved pick tool could pull it out or maybe drill 2 small
holes in seal and screw in sheet metal screw and pull out.
