Replacement Sand Blast gun
gzig5
Mequon, WI
I may need a replacement gun for my HF cabinet. It is the smaller side load table top model. Gun looks similar to the one in this pic. I just finished doing some upgrades to the pickup system, lights, and work support screen. The gun has a hole worn in the side where the media turns the corner. I think I can fix it, but I'm interested if anyone has found a decent gun that doesn't cost an arm and a leg. Needs to be relatively small, not a lot of room in the cabinet and it should have a trigger or I'll have to add a mechanical or electric foot switch. I've looked online and there seems to be a couple common ones but I don't want to replace crap with more or worse crap.
I have replaced mine with the Campbell Hausfield AT122601AV from Tractor Supply (and one from EBay) and they seem to work well. I picked up a few extra ceramic inserts when they were available and have only gone through two since the changeout. (I use them a lot too.)
Did the same thing.
I used the hand held gun from Tractor supply, it was like $11
The Campbell Hausfeld is $33 there now. A little cheaper from Amazon. but it looks pretty decent and would be in budget. The Scat Blast looks like the real deal too and cost isn't out of bounds. Good stuff.
I buy my cabinet stuff from TP. Their gun has adjustable jets so I can adjust it to work well with my "smaller" 5hp compressor.
