Replacing front brake lines of the 67 Dart and brake ?s
LAWFISH
Northern Nevada
Hey gang, I am replacing the front brake lines on my 67 dart, which was originally a /6 car, non power drum brakes. Now disc brakes and a 340 car.
I was thinking of buying those NAPA do it your self brakes lines and fitting them. Anyone had any experience with those. They would be a lot cheaper or do you guys like the done and fitted lines and if so, which ones.
Also, I have the original master cylinder, dial reservoir. Any suggestions on upgrades on this or adding a power unit?
Dave
I had an emergency fiasco with a 62 valiant-- went to auto zone---- bought the correct length/end fittings-- bought the cheap tube bender & patterned it after the twisted 1----- was not factory tight --but is still working great 3 years later. Less than $15 repair.
If I took more time, could have really snugged the bends to the firewall & frame areas.
Lawrence
