[SOLD] Restored 340 X-Heads (ported)
moparvinny
Macomb, MI
For sale are pair of freshly ported 340 X-Heads. The heads are ready to be bolted onto your small block Mopar engine. The heads were ported/assembled by a well known facility in Metro Detroit.
Below is a breakdown of the work that has been completed. Please note the heads have never been installed on an engine following the porting/reassembly processes.
Baked blasted and magnafluxed heads (no issues)
All tapped holes were chased
CNC Porting - intake ports / exhaust ports and chambers
Installed guide liners in the intake and exhaust guides
Installed harden seats in exhaust for unleaded fuel
Cut spring pockets to remove ID step
Cut for valve seals - cut top of guide for seals
Milled exhaust face - fly cut exhaust surface
Performed valve job - cut intake and exhaust seats and grind plus back cut valves (2.02/1.625)
Milled deck - 70cc
Installed freeze plugs
Washed and assembled heads with the following:
10-degree steel retainers
Comp Cams 10-degree 11/32" with no lash caps recess
Comp Cams dual valve springs 1.437 OD, 322 lbs./in. rate, 1.150" coil bind height
Comp Cams valve spring locator, steel, hardened, 1.500" outside diameter, 0.060" thick (set of 16)
Installed Manley valves - exhaust (stainless steel: 1.625", diameter: 0.3415", stem: 5.065" length)
Installed Manley valves - intake (stainless steel: 2.020", diameter: 0.3415", stem: 5.040" length)
If you have any questions, please let me know.
Price: $2,900.00
I reached out to the shop to see if they have the intake port volume on file. I did not see the spec called out on the sheet I have. Update to follow...
The Mopar community is so small that we cannot hide. Everyone knows our little secrets. Yes, Bob at Modern completed the work.
Unfortunately, Modern did not obtain the volume of the intake port. The did mention that it was a Stage III porting. I might need to locate a burette and get to measuring.
After the heads were completed, I started on my A-Body project where I ended up using 340 exhaust manifolds. A friend of mine advised me that I should avoid installing the ported heads on my 340, since I was using the stock exhaust manifolds and no stroker kit. Therefore, I purchased another set of X-Heads (less the porting) to retain the stock appearance. I do not have another project in the near future (for now), so I decided to sell the heads if someone needs at set. The cost is tied up in the porting. Those that are familiar with porting costs know that it's not cheap.
