Pabuhr
I have a very nice set of exhaust manifolds from a 1972 Dart. It was a low mileage car (29,000 miles). The manifolds had very little rust on them. The heat riser works perfectly. I bead blasted them along with the heat shield. Then painted them with high temperature paint. You won't find a nicer set anywhere. They will work for 1968-73 cars, but are date coded for a 1972. Casting numbers are as follows:2843953 & 3614395.
Located in N.E. Iowa
$125.00
$125.00
